Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
RES: Product Veiw or Express What do the differnt extensions meen.
Hi Ron,
.ed files stores produtc structures in older ASCII format, depends of .ol files containing geometry data
.edz files are kinda "ziped" files that contains both structure and geometry data
.pvs files are similar to .ed files but in newer format wich means small files, depends of .ol files too
.pvz files are the same as edz, it contains structure and geometry data in the same file.
Hope it help you.
Guilherme Rocha
De: Ron Rich [ This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
