hello,
i would like to ask if it possible (with restricted value parameter or something else) to choose for a parameter a value between a restricted value and something added manually.
for example: parameter XYZ could have a value N/A or a numeric value added by the user.
thanks
possible solution no.1:
Create a pair ofr parameters MYPAR_EX and MYPAR_VAL
MYPAR_EX = Yes means that MYPAR_VAL value is defined ... this represents MYPAR_VAL = numeric value
MYPAR_EX = No means that MYPAR_VAL value is not defined ... this represents MYPAR_VAL = N/A option
possible solution no.2:
Set numerical value that will represent N/A option ... for example 9999999999
A restricted parameter can have only one type. It cannot select from both a numeric and a text character string.
You could have a relation that detected that a given parameter was not present and set another parameter accordingly. Use the "exists(parameter_name)" function.
ok, thanks. but it is possible to set a parameter via drop down menu?
thank you very much,
i like solution n°1 but i have a question. if i set this relation:
IF MYPAR_EX==NO
MYPAR_VAL="N/A"
ENDIF
then i will have MYPAR_VAL as N/A. if in the future i will change MYPAR_EX to NO what will happen to MYPAR_VAL?
please explain your situation more precisely. I do not understand how are you going to use your parameter (containing numeric values or N/A string). Do you really need to have numeric parameter ?
sorry, maybe i do not have written right...
i need parameter to be STRING but with the possibility to have value N/A.
this is not possible via restricted parameter value so your suggestion is useful.
if i set MYPAR_EX to NO then MYPAR_VAL will be "N/A".
but if i change MYPAR_EX to YES then MYPAR_VAL will remain "N/A" and then i will need to change manually the value.
let us go back to restricted parameters...
I created list3.lst file containing following lines
ND_ParamDefArr_K01 = {
Name = mypar
Type = String
Default='N/A'
The I added following option into my config.pro file:
restricted_val_definition D:\users\mh\creo3_parametric\list3.lst
Test:
Is this what you want ?
Note: http://support.ptc.com/help/creo/creo_pma/usascii/#page/fundamentals%2Ffundamentals%2Ffund_seven_sub%2Fabout_Restricted_Value_Parameters.html page is start point of help.
ok, thanks.
i already use restricted_val_definition but in this case i would like to use (if possible) something like that:
Name = mypar
Type = String
Default='-'
ENUM = { '-', N/A}
but with the possibility to write a string instead of those values
try this one ...
Name = mypar
Type = String
Default='-'
ENUM = { '-', 'N/A'}
please upload your restriction file and test part. I can test your problem on my PC.
