RSD Overlay onto Pro/e drawing?
Marshdamp
7-Bedrock
In the past when we used pro/diagram we could overlay the diagram and
associated tables on to a Pro/e drawing that also displayed the flat
harness geometry. With RSD/creo schematic there seems to be no way to do
this. Does anyone know if there are plans to make the software be able
to do this? We've gone through several versions of RSD now and I would
have thought overlays would have been possible by now. It seems the only
thing we can do is export the RSD data to a DXF and then import it into
the Pro/e drawing. This seems more like a work-around than a solution.
To make a change you have to re-export the RSD data and then re-import
it into Pro/e and try to get it lined up where it needs to go on the
sheet again. We have also had a problem where, instead of finding
someone who can run RSD, a user has gone in and edited the imported dxf
data to change the diagram and now the RSD file is out of date. An
overlay would force people to go back and revise the original RSD file.
What are other's doing to get there RSD diagrams to show up on Pro/e
drawings?
aoler
(To:Marshdamp)
Yes, this is a problem. We have the same problem now as well but instead
of doing a DXF export we keep the files separate and just make a note on a
blank sheet in Pro/E that points a person to the correct *.rsd file so they
can open it up and print off the schematic. This prevents a person from
going in and changing the fake lines from the DXF.
The loss of Overlay has also taken away the "relationship" between the
drawing and the schematic. So now a User Defined relationship must be
created (in Pro/INTRALINK 3.x anyway) to keep the files tied together in
the PDM system.
I would say we spend a lot of extra time opening up both software and
editing the title blocks in both softwares to make both pieces of the
drawing match up. We also have an issue with the Title Block formats
looking the same between both softwares, even though it is a copy, they
just don't quite match up.
The DXF approach is the closest you will get to the Overlay, but in my
opinion also the most dangerous.
As far as your question about future plans to do this.... I wouldn't hold
your breath.
Aron J Oler
Senior Mechanical Engineer II
RTSC Central Engineering
Hardware Department
Raytheon Technical Services Company LLC
Raytheon Company
+1 317.306.4103 (office)
+1 765.977.6829 (cell)
635.4103 (tie line)
6125 East 21st Street
Indianapolis, IN, 46219 USA
www.raytheon.com
Follow Raytheon On
Twitter YouTube Facebook LinkedIn Dual Band podcasts
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
The way to overcome the danger of using the DXF approach is to save the drawing with the DXF as a PDF and submit that as the drawing.
