Can someone tell me if this is normal or if I have something wrong here. I realize they are very small, but my radii are showing up as straight lines in my drawing. Shouldn't they show up as blended radii like on my model?
Matt
I probably had to do with accuracy settings. If you do a regen do they then show up?
Thanks, Dale
Thanks, Dale
Thanks Dale... Changing the accuracy worked. That's good to know as I never mess with accuracy unless features fail. I didn't think it had anything to do with displaying a drawing.
Matt
Glad it help. Just don't got overboard with accuracy because it will cause performance issues if you get to much. You have to find a happy medium.
Thanks, Dale
