Rainbow Appearance Palette
TomD.inPDX
In case you ever needed a rainbow style palette but didn't want to go through the trouble to make one...
Here you go!
60 colors starting with pure red (01) to magenta (60)
6 pure colors at 01_pure_red, 11_pure_yellow, 21_pure_green, 31_pure_cyan, 41_pure_blue, & 51_pure_magenta
Increment coding is the deviation from the pure color to the next: ... 02_red, 03_red,... 10_red, 11_pure_yellow, 12_yellow...
The core settings are based on Generic with the following settings.
If you want to change any one parameter globally, just edit the file and replace the relevant line in all occurrences.
5 REPLIES 5
wow - Happy day.
Thanks for the gift!
My pleasure, Nathan!
double rainbow!
where i can find the file to be edited? cool work though
The file is attached to the original post (rainbow_60.dmt.zip). Just open the file in the appearance manager and it will install all the colors.
