Reconstrain Sketch Dimensions to Two Axis
al3
6-Contributor
6-Contributor
Have a sketch that is basically copied from a profile of external geometry and then deleted all references and picked two planes and then solved the sketch to make it independent of the external geometry. The only issue I have is that the sketch constraints try and dimension to one another. Is there a way to force the dimensions to not be able to dimension to one another but only go back to the default plane references i defined?
0 REPLIES 0
