What controls the display of ref dims in drawing mode? I want my ref dims enclosed in parentheses, not followed by REF. I've set 'parenthesize_ref_dim' to yes in my config.pro and I still get ref dims with 'REF' instead in my drawings. I've looked at the dimension area of the DTL file and don't see anything that seems to relate to ref dims.
Doug Schaefer
You will need to change your *.dtl file and you may also need to open the option and load it manually in to the part or drawing, because many of the options are only read when the part is created.
Brian S. Lynn Technical Coordinator, Product Engineering
