Creo 3, M170
Trying to replace components with unrelated option. In the interchange/tag dialog, after clicking evaluate...I see the two parts, tags, and tag icons on the models. But when I hover or click each tag in the table, no geometry highlights.
Is there a config option or something that I'm missing?
EDIT:
If I click repaint in the window after selecting a tag, the geometry references highlight...but that is a PITA to do after selecting every tag.
EDIT 2:
I see the same behavior when creating an interchange assembly. Tag geometry is not automatically highlighted, requiring a manual repaint in the graphics window to become visible.
This was a know bug in one of Creo 3.0 older builds.
I would recommend update to a newer build (I am using M150 and it works OK).
I'm using M170.
Sorry, forgot to mention that. Edited my first post.
