Reflection analysis Resolution is too low
mke-2
3-Newcomer
Hi all, I have use creo (pro/ engineer) about eight years, i want to make some high quality surface for the design ,so the surface analysis tools was so important.
There is a problem has been bothering me for a long time.The Resolution of the Reflection analysis in creo looks not smooth ,I search the net and found some way to slove this,but cannot works .I change the geometry display settings to very high and the anti_aliasing  to the high value . change the  model display  shade quliaty to he high value, but above thoes setting can not works .the refletion anaylsis is looks like the low resolution
How to solve this problem?
Thank you all  .Forgive me about my  poor English Smiley LOL
creo_refletion_analycreo_refletion_analyalias_refletion_anlyalias_refletion_anly
MartinHanak
(To:mke-2)
I do no know if it is bug. Try contacting PTC Support.
Also you can upload your model. I can test it on my PC.
Martin Hanák
7 REPLIES 7
MartinHanak
(To:mke-2)
1.] check your config.pro files ... look for graphics option ... what did you find ?
2.] what graphic card is installed in your PC ... how old are graphic drivers ?
Martin Hanák
mke-2
3-Newcomer
(To:MartinHanak)
THANKS FOR REPLY
I check those settng .the config file,have not the Graphic option found (I guess you think is the   graphics win32_gdi  option,).
I Use the creo 5.01.The graphic car is Quadro K600..I try to install the 320.27 date graphic driver.(download form the Nvidia.com). and rebot my compute and try again.It have the same problem .Is this is a bug?
MartinHanak
(To:mke-2)
Martin Hanák
mke-2
3-Newcomer
(To:MartinHanak)
The part just a simple surfe.You can try .the creo5 version prt
THankyou
MartinHanak
(To:mke-2)
I can reproduce your problem on my PC in Creo 5.0.1.0 and also in Creo 4.0 M060.
You have to contact PTC Support and ask them for explanation.
Martin Hanák
mke-2
3-Newcomer
(To:MartinHanak)
HAHA,Thankyou for your test.I try to use other to analyis the surface quality. Because this problem has the long time.Smiley LOL I will try to conatact the support.
pnewbury
(To:mke-2)
Hi all,
2 things:
In Creo 4 and before, you can add the config option: spherical_map_size 1024x1024
In Creo 5 (and I believe 6), there is a bug preventing that config from working but hopefully it will be solved soon.
Peter
