Regeneration failure in Assembly - Creo 11
NareshJ
I have been experiencing the issue as regeneration failure/missing component, I am unable to figure out where i have gone wring & not able to find a solution to fix the issue. it would be appreciated if anyone can help me with a solution.
Attached are the images FYR.
TIA
Naresh
Dale_Rosema
(To:KP_10260067)
If the components are in a different directory, make sure that the path to those parts are on your config.pro.
e.g.
search_path G:\Engineering\PROE_DATA\directory_of_parts_missing
Dale_Rosema
(To:NareshJ)
Images were not attached.
Hi Naresh,
Are the missing components saved in the same working directory as the assembly?
Dale_Rosema
(To:KP_10260067)
e.g.
