Relation between two different parts.
sbhushankumar
Hello Everyone,
Is it possible to create a relation between two different parts. For example , suppose I have created two different parts each having a hole of say 10 mm and 12 mm diameter respectively. Now what I want is If I edit the dia of the hole in the first part say I increase it by 5 to make it 15, the hole in the second part should update automatically to 17.
Please let me me know if this is possible and how.
Thank you,
Shashi.
huggre
(To:Gucio)
There are many methods you can use in Creo for this: skelletons, relations, notebook (layout), publish/copy geom. etc.
You just have to pick the method that is most appropriate for your requirement.
hi,
if you put those parts into asm- you'll be able to do it via relations.
regad,
gucio
Krzysztof
huggre
(To:Gucio)
TomD.inPDX
(To:huggre)
Find "top down design method in PTC Creo" in Google
