Relation in Drawing
manjunathrv
Relation in Drawing
My requirement is something like below in the drawing:
IF PTC_WM_LIFECYCLE_STATE == "Prototype Released"
PART_NUMBER = PART_NUMBER "X"
ENDIF
Ex: If state = Prototype Released then Part number is 12345678X
Else 12345678
Iam not able to make this work.
Is this possible? Anybody to help me?
BenLoosli
(To:manjunathrv)
Every regen recalculates the relations, so the extra 'X' will get added.
Try this syntax:
New_part_number = Part_number +'X'
else
new_part_number = Part_number
endif
7 REPLIES 7
Now I tried the below:
PART_NUMBER = PART_NUMBER + "X"
ENDIF
Now the funny thing is every time the drawing or model regenerates it adds one X at the end of part number.
Now my part number looks like 12345678XXXXXXXXXXXXX
mender
(To:manjunathrv)
Perhaps try 'if it is prototype released, and the part number does not end in X, then add X'?  As I recall, you use string length and extract to check 'ends in X'
The problem is Iam not able to build a working syntax....
How do I use string length in relations?
mender
(To:manjunathrv)
Ben's approach will also remove the X if the state is no longer prototype released.  If this is desired, use that.  If you want to flag but not unflag, I had originally been suggesting
if (extract(part_number, string_length(part_number), 1) != "X")
but looking at the dialog to find the precise syntax, I noticed
if (string_ends(part_number, "X"))
which is easier to read.
The part number should have X only for Proto state. for rest of the state its just the part number.
I will try your suggestion too.
Thank You.
BenLoosli
(To:manjunathrv)
Try this syntax:
else
endif
Thanks Ben. You got it.
I just changed this to :
part_number = New_part_number +'X'
else
endif
This works for me.
Thanks for your time.
