I would like to know how one can use OR into repeat region relation.
My scenario is as below:
If PartName = "001" or Param1= "001_Updated"
/*Do something
end if
Regards
Ketan
If you have OR you can do like this:
If PartName = "001"
/*Do something
end if
If Param1= "001_Updated"
/*Do something
end if
If CREO has no "OR", you can use a variable as a way around it.
i = 0;
if i=0
if partname = "001"
/*Do
/*i=1
end if
end if
if i=0
if partname = "001_v2"
/*Do
/*i=1
end if
end if
This way, in case you have both, it won't do the same action twice.
There is an ELSE function that may work.
I haven't tried this, so it may need to be tinkered with:
IF PartName = "001"
/*Do Something
ELSE
IF Param = "001_Updated"
/*Do Something
ENDIF
ENDIF
I need to do same thing for PartName as 001 and 001_Updated both... Else condition will not work as repetition will happen. In addition to that, I do have scenarios of 002 and 002_Updated and so on as well....
Regards
Ketan
Use the "|" to represent the OR function. "&" is for AND.
Creo relations, including repeat region relations, uses the ampersand (&) for AND and the pipe (|) for OR.
IF PartName == "001" | Param1 == "001_Updated"
/* Do something
ENDIF
Sorry David. Your post wasn't visible when I was replying. Hopefully the forum bug isn't back.
