Relations & family tables
John.Pryal
Hi all,
is there a way of driving a dimension in a family table instance? Lets say i have a cylinder 100mm long, with a diameter of 25mm which is my generic, & i have an instance that is also 100mm long, but has a diameter of 25.5mm. I open the instance & add the relation "d8=d8+0.5 & it kind of works for me, but something is not right. Both models fail to fully regenerate, i get an amber light. Plus, why do i see the relation on my generic part, even though it does not take effect. I just want the relation to be active in the instance. I want to be able to modify the diameter of the generic & know the instance will always be 0.5mm larger.
Thank you in advance
John
6 REPLIES 6
That relation is trouble. Everytime you regenerate it will increment the value. This sort of relation can actually be used to step through something, say varying the angle of a crankshaft to make a piston cycle, but not what you want here. If I understand your situation correctly, you need an independent value you can change. For example you create a parameter called Base_Diameter and give it a value. Then use relations to set the values for the various instances relative to that Base_Diameter.
John.Pryal
(To:DavidButz)
Thank you for your reply David, indeed, what you describe is what i want to achieve. That is a shame, being able to wite such a relation & have it work correctly would have been very useful for me.
Regards
John
You can still do pretty much what you want, even use a column in your table for the values. For the generic you would have d8=BD, for the instance d8=BD+.5. (Shortening Base_Diameter to BD makes it easier to deal with in Relations.) Having the same variable, d8 in your case, as both a dependent and an independent variable is really not good logical form unless you are trying to do an incrementing trick like the one I mentioned above.
John.Pryal
(To:DavidButz)
Hi David,
what you have just described is what i have been trying to do for the last hour. I could be wrong, but when you write a relation with family tables you see it both the generic & the instance. It would appear that the last relation written, overrides the first, i end up with both the generic & the instance with a dia. of 25.5 instead of 25 & 25.5. Thank you very much for your help thus far, i don't want to be a pest, but if you have any further thoughts, i would appreciate them.
Regards
John
Hi John,
Sorry about that; I didn't really think that through carefully enough relative to the way a Family Table works. You really need another intervening parameter.
Here's how I made it work. Create 3 parameters, A, B, & C, create the relation A=B+C, and the relation d8=A. Set B to the value of the generic diameter, C to 0.0, and add the parameter C to the Family Table as a column. Now set the value of C for the instance to 0.5 and you should get what you want. (I hope!)
David
John.Pryal
(To:DavidButz)
Bull's-eye!! thank you very much David, that is exactly what i wanted to do, i was concerned about having to enter the same value twice for parameters A & B, but that is not the case, because of the second relation, it locks parameter A, so only B needs a value. In fact, you have opened up all kinds of possibilities for me with this, i have been working with relations for a while now, but never with parameters, & never combining the two. Thanks once again.
Regards
John
