Relations help......
ptc-222962
HI All,
This should be simple but I’m having issues, I'm attempting to write the relation shown directly below which works fine when this exact P/N is used. The issue is..... I wantthe first five characters (12345) and the last two (00)to be a wildcards so anywherethe relation see's "-67-89-" it'll complete the other parameters automatically.
if PART_NUMBER =="12345-67-89-00"
MATERIAL = "WOOD"
MATERIAL_SPEC = "RED OAK"
FINISH_CODE = "89"
ENDIF
I've attempted to use asterisksfor wildcards (as below)… this doesn’t work…. Any help would be appreciated!
if PART_NUMBER =="*-67-89-*"
MATERIAL = "WOOD"
FINISH_CODE = "89"
ENDIF
Doug
Use the extract(string, position, length) function to pull out only what
you want.
PART_NUMBER_MIDDLE = extract(PART_NUMBER,6,7)
IF PART_NUMBER_MIDDLE == "-67-89-"
MATERIAL = "WOOD"
FINISH_CODE = "89"
ENDIF
Hope that helps,
Brian S. Lynn
Technical Coordinator, Product Engineering
RonThellen
(To:ptc-222962)
That solution works as long as PART_NUMBER always starts with five characters before the first “-“, which may or may not be the case.
The following provides a little more flexibility (I added the else statement for testing purposes, but it could be useful in the final relation):
if search( PART_NUMBER, "-67-89-") > 0
MATERIAL = "WOOD"
FINISH_CODE = "89"
else
MATERIAL = "???"
MATERIAL_SPEC = "???"
FINISH_CODE = "???"
endif
The “search” function looks for the specified string. If it is found, it returns a non-zero value. If it is not found, it returns 0.
Ron Thellen
CAD Administrator
Engineering & Manufacturing Applications
Government Communications Systems Division
Harris Corporation
321-729-7502
You could use the search function
RESULT = search(PART_NUMBER, "-67-89-"
IF RESULT > 0
MATERIAL = "WOOD"
FINISH_CODE = "89"
ENDIF
The search() function returns the location in the string of the search term
(in your case, 6, since the - is the 6th character in the string. If the
search term is not found, it returns 0.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
MATERIAL = "WOOD"
FINISH_CODE = "89"
ENDIF
I've attempted to use asterisks for wildcards (as below). this doesn't
work.. Any help would be appreciated!
MATERIAL = "WOOD"
MAT...
Hi All,
Several people suggested thesame method (below) and it works fine! Thanks to all!Doug
MATERIAL = "WOOD"
FINISH_CODE = "89"
endif
