Relations_to_verify.log
JLG
We recently moved from Creo Parametric 2.0 M100 to M130. I opened an assembly containing some models that use relations, and a Relations_to_verify.log file was generated in my working directory. The first lines of the file say "Evaluation of relations in a newer version of PTC Creo" and " The following symbols may impact relations evaluation:". Then it lists the models affected and symbols (dimensions in this case) that are being assigned to.
Does anybody know what changed? What sort of errors may be occurring? I don't have any idea what to look for.
Thanks!
Kind regards,
Janet Grove
1 REPLY 1
JLG
(To:JLG)
I received one answer that sounds like the correct reason for the messages:
"...there was a bug with angle dimensions that was identified and fixed within those releases."
Since all the dimensions reported in the Relations_to_verify.log file were angular dimensions, I think that's why the file was generated.
Thanks again to all you folks in ptcuser-land. I will sorely miss this forum when it's gone. You've taught me a lot.
Kind regards,
Janet Grove
