Relationship between features.
WA_2025
3-Newcomer
I am looking for a feature in Creo that allows you to select faces of two features and determine the relationship between them. For example, in SolidWorks, if you select two flat surfaces, it will show whether they are parallel or perpendicular in the bottom right corner or the analysis window. Similarly, if you select two circles, it will indicate if they are concentric or offset. Is there a feature in Creo that provides similar functionality or something close to it? Thank you.
use Analysis > Measure tool.
Martin Hanák
Hi @WA_13679242,
Anurag
