Remove all breaks in an axis line
Trebla
I have a question in drawing environment,  about axis lines that already have a break because there is a dimension there:eix_1.jpg
some days after, the dimension is no longer necessary, so I delete it. How can I remove the break in the axis line?
I am using creo4. Thank you very much
StephenW
(To:Trebla)
While in the Annotate tab, select the Axis, then in the ribbon in the Delete area, there is REMOVE ALL BREAKS icon.
1 REPLY 1
StephenW
(To:Trebla)
