Hello Team,
I know using this option to remove file history.
(PURGE_HISTORY_ON_SAVE_COPY = YES)
induvial drawing and part save a copy is not an issue.
But along with drawing how to remove the file history in model?
The config setting works on all files you save a copy of. To erase the file history of the model and keep the name, save a copy, delete the original, rename the copy back to the original name.
