Removing material in an assembly
ChristianSmith
I have an assembly with various parts. I have a perimeter with parts that go past that point that I want to use an extrude for example and cut the excess material away so I can get a nice clean edge. When I do that it says my sketch is outside the model. What's the easiest way to remove material like this...taking away material from various parts?
If there are parts the cut section doesn't intersect to remove material remove those parts from the intersection list on the Intersect tab.
1 REPLY 1
