So I have an assembly and i want to export to step file, but all my files has to come with this name: MX_Revision_A_18_06_2020.step. How can I do that? Any thoughts?
Thank you in advance 🙂
Mariana Sousa
Mariana Sousa
1.] you have to explain procedure for name generation (in detail)
2.] you have to create macro for STEP export
Example of data: main assembly "Molde_10.asm" with 3 parts "100.prt"; "200 .prt"and "101.prt". I want to export to STEP file, and yes I already have a mapkey to export to step. But i want to export all my files with the name "Molde_10_today_date_rev_A.stp", "100_today_date_rev_A.stp", "200_today_date_rev_A.stp", and "101_today_date_rev_A.stp".
The sufix "_today_date_rev_X.stp "will change all at once "X_today_date_rev_X.stp".
With my mapkey files are generated with this name "Molde_10_top.stp", "100_prt.stp", "100_prt.stp" and "101_prt.stp".
If I do "Save as" i know that i can choose the name file, but it takes lot of time if i have many subassemblies or parts.
my first idea ...
1.] open Molde_10.asm
2.] change working directory to empty auxiliary directory
3.] Save As assembly into auxiliary directory ... you can modify model names according you needs in Save As dialog box
4.] erase Molde_10.asm from memory
5.] open Molde_10_today_date_rev_A.asm
6.] export Molde_10_today_date_rev_A.asm assembly into STEP
7.] delete files from auxiliary directory
The parts that i have at my main assembly won't change to name "molde_10_today_date_rev_A".
I think that is not a solution for assemblies with one hundred parts/asm.
Are there something to rename all my files after I export them? Maybe a batch file, I don't know?
I uploaded STEP_export.mp4 video showing procedure mentioned in previous reply.
Note: If you decide to rename your files after export, then you have to modify names saved inside STEP files, too.
Additional note:
Creo model name length maximum = 31 characters
Thank you for your video 🙂
I will test this steps that was on your video in a mapkey.
A simple rename insession of your models using CRESON (Open Source Automation for Creo) would be fast and effective - with a final export of the STEP.
basically:
file : open <asyname>
for each parts/assembly....
file : rename <curname> <newfilename> -onlysession true
with a final....
interface : export <newasyname>
With a bit more work you could extract information from the models (parameters/values) and have the entire process automated.
Dave
What is that? an application for Creo? Free?
