Repeat Region Relations
ptc-859099
7-Bedrock
I am having a problem getting 2 relations to work on my BOM. Our part numbers are in a column called asm.mbr.name I then go in and add a parameter by right clicking the bottom cell in this column going to report parameter>rpt>rel>user defined this parameter is partnum My goal is that I need some of the part numbers to be shown as "------" so that a blank spot is left in the BOM, others I have different configurations of the same part, like I have 123_a, 123_b, 123_c and I need to get rid of the _a, _b, _c. I have 2 relations that work fine when only one of them are used but when I attempt to use both of them only the one that is list last will work. My relations are as follows IF asm_mbr_name != "NULL" pointer = search(asm_mbr_name,"_") IF pointer == 0 partnum = asm_mbr_name ELSE index = pointer - 1.0 partnum = extract(asm_mbr_name, 1.0, index) ENDIF ENDIF IF asm_mbr_name != "NULL" pointer = search(asm_mbr_name,"_") IF pointer == 0 partnum = asm_mbr_name ELSE index = pointer - 1.0 partnum = "--------" ENDIF ENDIF I have went in on the 2nd line of each and changed the "_" to the actual part number but that doesnt work either. Any one have any ideas?
Issue has been resolved. The relation I posted was originally written back in 2001, it seems as if it had too many variables. Simplified the one that changed the part numbers to ----- and it works fine now.
