Repeat region: identify wire harness/cable.
ER_10382549
Hello, everyone.
The challenge is: How to identify wire harness/cable components directly from a repeat region.
Version: Creo 10.
Assemblies, parts, and skeletons can be easily identified from the common repeat regions. Then, piping and sheet metal parts can also be identified from their unique parameters.
Is there a way to idenfity cables/wire harness components from their parameters or properties?
- By clicking "Bill of materials" button from ribbon, we get the .txt file with cable details, but this is totally useless for general BOM purposes.
- Adding a new parameter is not feasible, considering the "universe" of assemblies/parts that would need to be revised. Then, not this way.
Thank you in advance.
2 REPLIES 2
Hi @ER_10382549,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best Regards,
Vivek N
Community Moderation Team
Hi @ER_10382549
There are report parameters that are specific to cabling and harness models as well.
https://support.ptc.com/help/creo/creo_pma/r10.0/usascii/#page/electrical_design/cable/about_parameters_in_report_tables.html#
Hope this helps,
Mike
