Repeat region table crash
cwilkes
Creo 1.0:
I've created a couple BOM tables on a layout in a drawing file using repeat regions. I've tried several times to 'Save Table" to a file, so I can use the same table elsewhere. Each time I do, Creo stalls for a few seconds, then closes all windows. I have access to the location in which I'm trying to save. Anybody have any ideas as to why I'm crashing?
One clue: When I try to save the table, after Creo crashes, it leaves a .jpg file in my target folder with the filename I specified. When I open the .jpg, all it shows is a small red X. When I open Creo again, if I click "Load table from file", my table shows up there as well as a .tbl file. If I try to load that table, Creo crashes again.
1 REPLY 1
cwilkes
(To:cwilkes)
by the way, I've used this method of saving/loading BOM tables several times before, so I don't believe it's an issue with my computer/network. there's something about this particular table or file that's causing the crashes
