I need to have the model parameters show up in a combination state. The combination states are passed thru
to Creo View 2.0 and I want the down stream process users to see the model parameters without having to interrogate
the model. This process is for commercial items that are used in our assemblies and would not normally require drawings.
The reported parameters will serve as the baseline 'Component Data' for the Commercial item.
