Residual table problem
fwadlinger
In the attached file, there are two table outlines which I cannot remove. In fact I cannot select them in any way to remove them.
I removed the format file and all models, and still they persist.
The real problem is that when a 'save a copy' is performed, they copy to the new drawing.
Anyone have any ideas?
TIA
1 REPLY 1
Interesting problem.... Anyway, you can create a new sheet and then delete sheet 1. Rename sheet 2 to be sheet 1 and the tables will be gone.
Ronald B. Grabau
HP PDE-IT
Roseville, CA
916-785-3298
-<">mailto:->
