Restricted_Param.txtx not reading all
BenLoosli
I added a new classification to an existing parameter list in the restricted_param.txt file. Restarted Creo and the new parameter is not being loaded to the drop down list for that parameter.
I know it can't be number of items per parameter, as that one only has 6 and I have others that have 20.
Is there some file size limit that I may have exceeded? This parameter is at the top of the file.
There is also a model check restriction when checking in a file that the parameter value must be on the list, so I modified the model check file, too.
Has anyone seen issues with restricted_param.txt files that don't load the full list?
Creo 2 m200
Windchill 10.0 m040
BenLoosli
(To:BenLoosli)
total brain fade...I forgot to update the list in my file.
All fixed
