I've create a restricted parameters table of fastners and it's working nice as expected. The only issue I'm having is, that I want the restricted parameters table to follow the part without having the file read each time Creo is started. I know it works with a restricted parameters file (not restricted parameters table) when you save the part. With the restricted parameters table, when saved off, it keeps the parameter name with only the last selected option from the drop-down list.
Is there a way to accomplish this?
Hello @gpedros
Yes. This was what @MartinHanak suggested. No need anyway, as I give PTC Technical Support's answer here in this post.
What you're facing is a current limitation. When driving presence of parameters with pre-defined values coming from tables in restricted parameter files, according to guidance documented in article 66567, the names and values of parameters are walwyas read dynamically in the file where restricted_val_definition config.pro option points to.
In other words:
This is illustrated in little movie below.
Based on above considretaion:
Serge
please discuss the issue with PTC Support.
Hello @gpedros
In other words:
Serge
