Restructure in CREO
falcalde
Restructure in CREO
Good mornig, I wanna know where is the restructure command in CREO?, I can´t to find. may be it,s changed in this versión.
Thank you,
2 REPLIES 2
Hey Francisco,
did you know that creo has a integrated command search?
ScreenShot 851 FRAME (Active) C__temp_creo_EFX_PROJEKTE_EFX-Schulung_EFX-Schulung_ADV_separate_weldments_done_frame.asm.6 - Creo Parametric.jpg
greetings sam
Samuel Brantner
B&W Software GmbH
You can go to MODEL "Tab" then go to COMPONENT "Gascade" you will find the structure command
