Revit dump
brianlynn
Revit dump
I have been asked to export some Pro/E assemblies as Revit assemblies or
models for space claim in customer layouts. Is it possible in WF 3 to
export to Revit format, and if not is there something I can export from
Pro/E WF 3 that Revit will read in easily?
Thank you,
Brian S. Lynn
Technical Coordinator, Product Engineering
Brian,
I recently got a similar task..
So, I had to do some investigating and a lot of trial and error.
Here are the results:
There is no direct transfer/export from Pro/E to Revit, so we need a
neutral format.
What can be done is to export as SAT file, this type of file can be
imported into Revit with SOME success.
Is just that you have to be careful with file size and export first a
Shrinkwrap the reexport the resulting file as SAT.
Look for file sizes of less than 10Mb.
Do different version cutting back from Pro/E assembly details until you
get the desired result with a small file size.
I would be interested if you find different answers to this.
Hope it makes sense what I tried to explain.
Let me know if you need more details.
Hope it helps.
Here is the summary containing the original and the 3 responses I
received.
Brian S. Lynn
