Hi there
wondering if anyone knows how to regenerate a single part in an assembly without having to regenerate the whole assembly.
In Creo 2.0 I use to be able to right click a part on the assembly tree and regenerate that part via the popup menu, however in Creo 3.0, the right click menu is missing the option to regenerate. Attached is a screen shot of the popup window on creo 2 and 3.
Is there a way I can get the "regeneration" option back in creo 3.0?
I am also looking for this feature.
Hi Lisa & Steve,
If you have a PTC account, you can get further information via the following article:
If you don't have an account, you can create one here.
The gist of the article is:
Amit
your link does not work for me.
See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS195374
MH
Thanks Martin. Not sure what happened to my link.
I used that command in Wildfire and in Creo 2.0 and it seemed to work the way I expected. PTC doesn't see its not working as an issue?
