Right Click part in Assembly tree - menu missing the regenerate command in Creo 3.0
lgyecsek
2-Explorer
Hi there
wondering if anyone knows how to regenerate a single part in an assembly without having to regenerate the whole assembly.
In Creo 2.0 I use to be able to right click a part on the assembly tree and regenerate that part via the popup menu, however in Creo 3.0, the right click menu is missing the option to regenerate. Attached is a screen shot of the popup window on creo 2 and 3.
Is there a way I can get the "regeneration" option back in creo 3.0?
6 REPLIES 6
saw
(To:lgyecsek)
I am also looking for this feature.
Hi Lisa & Steve,
If you have a PTC account, you can get further information via the following article:
CS195374 - "Regenerate" does not exist in context menu of a component in assembly in Creo Parametric 3.0
If you don't have an account, you can create one here.
The gist of the article is:
  • Using RMB > Regenerate after selecting a particular part/component, did not regenerate the component selected
    • Regeneration would take place on the entire assembly
  • Since this was not in the spirit of the context command, it has been removed in Creo 3.0
Amit
your link does not work for me.
See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS195374
MH
Martin Hanák
Thanks Martin.  Not sure what happened to my link.
The forum still plays games with links.  You have http://https//support...
I used that command in Wildfire and in Creo 2.0 and it seemed to work the way I expected. PTC doesn't see its not working as an issue?
