Any suggestions on how to incorporate rolled threads and cut threads into IFX hole tables?
Hi Kelly,
do you already have hole charts for this type of threads?
How do you create rolled thread with Creo at the moment?
We use the default hole charts for our threaded holes. When a rolled threaded is identified, the desired diameter for the drill size is changed in order for the CAM software to choose the correct tooling (drill and tap).
Hi Kelly,
some background information on IFX:
What you can do is to use the THREAD value to control which hole chart should be taken. But of course you need different hole charts for threaded and rolled threads.
Questions:
