How can you route more than one wire to the same pin in a connector? When I try I get an error that reads "cannot route more than one cable to WIRE entry port." I have seen models that have two wires in the same entry port.
Keith,
Change GROUPING to ROUND on the entry port.
jef
Hello Keith,
did the suggestion from Jeff work for you?
The community is always interested to learn, whether suggestions are helpful or not.
Please, when you have the time, follow-up with a comment and/or just mark his answer as correct.
Gunter
