Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Can anyone tell me why SPR 1634275 is not "Customer viewable"? Baffling...Top Secret? When using #Insert #Shared Data #From File to insert a pre-existing drawing into a new drawing as a separate sheet, several notes in the pre-existing drawing that call out parameters end up disappearing or showing different values. <">http://www.ptc.com/appserver/cs/view/spr.jsp?n=1634275>
