I recently upgraded from 3.0 to 4.0 and the STEP export has a different interface. My assembly files always have layers that are hidden, and until now these layers were excluded when exporting to STEP. All items on hidden layers are being exported and this is creating a huge problem for the people who read in my STEP files. The result is a bunch of unwanted clutter.
I have unsuccessfully tried to find a configuration setting for this. I've played around with the settings for "Customize Export" with no luck also. I've changed the export status to all different settings including Blank, Exclude Content, and Ignore, yet still the items are present in the STEP file.
I need to know how to export to STEP while excluding items on hidden layers.
Please set configuration file option intf_out_blanked_entities to no , then try to export again.
That was the default setting; ity was already set to "no."
I used PTC Technical Support Search and searched for STEP export layer hidden.
I received a list of results, two of the are...
https://www.ptc.com/en/support/article?n=CS53119
https://www.ptc.com/en/support/article?n=CS121729
Layers can be exported using AP214 or AP203 dependent on the config setting for step_appearance_layers_groups
I did not test any of these solutions...
