STEP File
ptc-5365583
STEP File
I recieved a STEP file.I have the problem to change some measures.How is it possible?
2 REPLIES 2
Welcome to the forum, Platini.
The only feature for changing import files directly is the data doctor. However, you can add features to the import model to make changes. You also have the option to scale the model in case it uses the wrong units.
Is there something specific you would like help with? You can save screenshots and post them in the forum.
Inoram
(To:ptc-5365583)
A STEP import will not give you a feature list in the model tree. But you can use Flexible Modeling (if you have it) to change features a bit. Or just start modeling on what you have.
