STEP Files For Pro cabling
ptc-1315472
2-Explorer
Could anyone explain me about creating STEP files for Pro Cabling assembly in wildfire
Senthil
gkoch
(To:ptc-1315472)
There is an export option, to export cable surfaces.
However, it works correctly only since Creo Elements/Pro 5.0
For Pro/ENGINEER Wildfire a workaround was required, as the cable surfaces were only exported with the surface option and not with the solid option.
The workaround required setting config.pro option step_export_format ap214_cd and exporting in two steps (solid for models and surface for the cables).
See article CS66555 : Export of thick cables does not work for for interfaces such like IGES, STEP, CATIA V4 (.model), ACIS, Parasolid, UG in Pro/ENGINEER Wildfire 4.0
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS66555
