STL-Export of Single Parts
ckorsten
Hi All!
I am testing Creo for our works purpouses. Is there a quick way to export the single parts of an assembly as stl as single entities? All creo does ist exporting it as a single mesh.
Thx for your help mates!
4 REPLIES 4
Hi Christopher,
Just to clarify, and make sure that I understand, you would like to export an assembly, containing, say 5, components, to the STL format.  After export, you want 5 different STL files, 1 for each of the components in the assembly.
Is this correct?
Amit
Hi Amit,
yes exactly. I have seen that there is an option to export every single component, but I would have to use it 5 times. Thats not option for larger modells with 20+ parts. Is there a quick solution.?
Thanks a lot,
Chris
Depending on what you do with the STL files, many programs will let you break apart an assembly on the build plate and then treat them individually.
You might also look at some of the other facet export formats.  I had one dump separate files on me one day and that is not what I wanted.
However, I like the option... hope it is there already.  If not, maybe an Idea can be submitted.
requested functionality is not available. You can create your own software solution. Before you start programming, you need to know:
  • how to create a list of components (for example, you can save customized BOM of your assembly)
  • how to export single part into STL (you will get sample trail file)
  • how to generate trail file executing STL export for list of components
You can use AutoIt software to create a tool with requested functionality.
MH
Martin Hanák
