Save WF4 models as WF3?
ptc-2495853
1-Newbie
I use two different versions of Pro/E depending on the location I am working at for my job. I just had the issue come up with I will be creating a part in WF4 that will need to be opened in WF3. Is this just a straight up save and WF3 will read the part or is there something else I need to do such as download a plugin to save as a WF3 file. Thanks.
1 REPLY 1
Chase, The other way around. You need to download the Granite kernel so that you can open 4.0 files in 3.0. See: https://www.ptc.com/appserver/cs/view/solution.jsp?n=132326 David
