Save as an assembly mirror
luiz.hnm
11-Garnet
I created an assembly using skeleton and I want to create a mirrored copy. I tried to save as a copy but I think that due to the complexity, the result presents errors. I just want to save it as a mirror, but it could be as an IGES part. I'm saving an iges and opening the iges and mirroring it, but in Windchill this process is slow. Is there any more direct way to do this?
6 REPLIES 6
tbraxton
(To:luiz.hnm)
I am assuming that you saved the assembly as a mirror as outlined here: About Mirroring Assemblies (ptc.com)
If that is not working, then consider simplifying the mirror operation. If the components are all constrained to the skeleton for location/orientation you can try mirroring the skeleton only and assembling to the mirrored skeleton.
Involute Development, LLC
Consulting Engineers
Thanks for the answer!
And if I have flexible components, will the mirror command have more difficulty generating?
tbraxton
(To:luiz.hnm)
I have no experience with mirroring flexible components. I would suggest making a simple assembly as a test case to understand what happens with flexible components when mirrored.
I tried and the mirror didn't work with flexible components. So, all i want now is to save a mirror in a format like an iges or shrinkwrap, but changeable by generic when it changes. Is that possible?
tbraxton
(To:luiz.hnm)
You could semi-automate the export of an IGES or STEP file, read in the export model and then mirror this model in Creo. Mapkeys could automate most of this process, but you would have to manually execute the mapkeys each time you change the generic source model.
If you provide some additional details and ideally some test models, then maybe someone would offer some specific guidance for the flexible components.
Or like a representation.
