Embedded piping parameters
Matthijs1
I am exploring the piping option to use in our assemblies. Because we are working with a PLM system (Windchill), I need to embed the pipe pieces created with the piping option. Otherwise each little piece of pipe will get an article number in Windchill.
What I would like to get is for the assembly that contains the embedded parts, to get a parameter: materialcode & length for each type of pipe used.
Any other ideas are welcome as well. The moral of the story is: The pipes are embedded but I want to be able to extract the materialcode and length of each type used, regardless of the amount of pipe pieces.
Are there possibilities here? All I can find is a little menu that can tell me the length of certain pipes and store it, but it's not extractable nor does it update.
Hi @Matthijs1,
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
