Save simplified Rep to external file: PROBLEM
nkaminakis
Hi all,
I have a pretty complicated assembly and I want to create some kind of
assembly processes for specific
areas. I create a Simplified rep which I want to save to an external file.
Then i get this message:
"Please confirm excluding missing components". If I click "yes" I get the
assembly open in a new Pro/E
window, with some components missing.
Does anybody knows what is wrong?
Thank you!
-nk/.
-nk/.
Some updates:
I use Creo Elements/Pro 5.0 M70 on XP64.
I have tried to create a external simplified rep as it is mentioned in the
help file
without any luck.
The funny is that when I select to open the assembly (step 5) from which I
want to create the
simplified rep, I don't get the assembly open in a new window. Instead I
get an empty assembly file.
Then I create the rep in the main assembly, followed the same steps, I
choose in "step 5" to open a rep, I select the rep
and the I get the same empty assembly file.
Is this a bug or something???
To Create an External Simplified Representation Using the New Dialog Box
This procedure creates an external simplified representation without
opening the reference assembly.
1. Click File ▶ New. The New dialog box opens. 2. Click
Assemblyand select Ext.
Simp. Rep from the Sub-type list. 3. To use a different template clear
the Use default template check box. 4. Enter a name for the external
simplified representation or accept the default and click OK.
Note
When you clear the Use default template check box the New File
Optionsdialog box opens. Select a template and click
OK.
The Open dialog box opens.
5. Select a reference assembly and click one of the following:
● Open—Opens the assembly in a separate window and the EDIT:DEFINITION
REP dialog box opens. A second column labelled DEFINITION REP appears in
the dialog box Model Tree. By default Master Rep appears next to the
assembly name. Use the check boxes to specify components for inclusion or
exclusion from the external simplified representation. Click OK when
complete. ● Open Rep—Opens the Open Rep dialog box. Choose one of the
following operations:
○ Select a representation type and click OK. Define the simplified
representation and click [image: Image] when complete. ○ Click Define.
Enter a name for the simplified representation at the prompt or accept the
default name and click [image: Image]. Define the simplified representation
● Cancel—Opens the external simplified representation in a new window.
To add a reference assembly select the external simplified representation
in the Model Tree, right-click, and choose Edit Definition. The Open dialog
box opens.
Note
The Enable On-Demand Updating option is available for a representation type
other than the Master representation.
-nk/.
