I had never heard of variant_drawing_item_sizes so, intrigued, I gave it a try. Didn't get any scaling pasting a table into a different size drawing but did get scaling when changing sheet size. Unfortunately, while the table scales, the text in the table does not. At least it is pretty easy to change all the text style in one command if it's all the same size. Interestingly, the default text size for a new row in the table did scale. So as usual, PTC got it 75% right.
In Reply to Tom Uminn:
The only way I've ever found to scale a table correctly is to turn on the config option "variant_drawing_item_sizes" and then change the sheet size proportional to the table scale change needed. It's probably easiest to copy the table to a temporary drawing with simple dimensions like 10" x 10", turn on the config option, change the drawing sheet size to a scaled up value (like 20" x 20"), turn off the config option, and copy the table back to the original drawing. Just make sure you don't leave the config option on, or a table will automatically resize itself every time you drop it on a different size drawing.
Tom U.
