Hello all and thank you ahead of time for any responses.
I downloaded an assembly from grabcad as a step file, imported it into CREO 2, and then attempted to scale the model and it is not scaling. I clicked "Operations", "Scale Model" then entered a value of 0.66 because the length is 18 and I would like it around 12. The system prompts me to accept the scaling and regeneration to which I click OK, and in the bottom left of the screen it says "rescaling dimension", but nothing ever happens and the models dimensions stay the same. The model has about 40 parts, my PC is Core i5, and I have given it over a half hour to process but nothing. Any suggestions?
Tom
Hello Thomas,
think you're in the wrong forum.
Here's Creo Elements / Direct
