Screw and fastener in creo
bcat
9-Granite
hello again
I want to assemble screw and fasstener
how i do ?
creo/proe have library with those?
must to draw screws? or existing in library?
if exist where is?
i suppose proe have a module separate its true?
/thanks
the best way to learn is to ask
sorry for stupid question
DHLewis
(To:bcat)
In Creo 3 there is finally a built in library of parts. It is a Lite Version of Intelligent Fastener Extention.
See this item:
http://communities.ptc.com/thread/55956
As it seems to not play well with Windchill. But if you don't need that, then it should work fine.
4 REPLIES 4
TomD.inPDX
(To:bcat)
There are many web sites that let you download hardware files. There are some 3rd party links in the Creo browser also. There are also a few libraries posted in this forum. I prefer to create my own for consistency.
DHLewis
(To:bcat)
See this item:
In Creo 3.0 M020 we have extended the allowable out of the box parameters to include additional Windchill and Model check parameters.
I hope this will go some way to improving the integration of the free version of IFX with Windchill.
The additonal parameters are as follows
"PTC_MODIFIED"
"PTC_ORGANIZATION_ID"
"PTC_WM_VERSION"
"PTC_WM_LOCATION"
"PTC_WM_TEAM"
"PTC_WM_REVISION";
"PTC_WM_PART_NAME";
"PTC_WM_PART_NUMBER";
"PTC_WM_NUMBER";
"PTC_WM_NAME";
"PTC_WM_ORGANIZATION_ID";
"PTC_WM_ITERATION";
"PTC_WM_LIFECYCLE";
"PTC_WM_LIFECYCLE_STATE";
"PTC_WM_IS_DRAWING";
"PTC_WM_PART_REVISION_FOR_DRAWING";
"PTC_WM_PART_STATE_FOR_DRAWING";
"PTC_WM_CREATED_BY";
"PTC_WM_CREATED_ON";
"PTC_WM_MODIFIED_BY";
"PTC_WM_MODIFIED_ON";
"PTC_WM_LAST_CHANGE_NOTE";
"PTC_WM_LIFECYCLE";
PDMREV
PDMDB
PDMRL
PROI_REVISION
PROI_VERSION
PROI_BRANCH
PROI_RELEASE
PROI_MODIFIED
!MODELCHECK
MODEL_CHECK
MC_ERRORS
MC_CONFIG
MC_MODE
Thank you and PTC for due consideration of this oversight
