Once in a while, I, or one of my colleagues, neglect to set the density of a part and the mass of the assembly is reported as something huge.
Usually, I show the density and mass in the model tree and I can scan for silly numbers by eye.
However, when the assembly has a large number of parts, it is easy to overlook the offending item, especially if it is in a sub-assembly.
Is there a way to use the Search icon to look for components in which pro_mp_mass is greater than a certain value, or, indeed, in which pro_mp_density is 1.00?
I can only work out how to search for a user-defined parameter called Mass which is greater than a certain value. Our parts do not need a Mass parameter, however, since they automatically have a pro_mp_mass parameter. I am certainly not in a position to add such a parameter to every part in the database.
I even tried using Modelcheck to find parts with default density (DEF_DENSITY test), but I couldn't get that to work, wither.
I suspect the visual scan is the answer, but, if there is a way to search for a value of pro_mp_mass or pro_mp_density, I would be pleased to hear how.
Wildfire 4, M220
Cheers,
John
John,
in Creo 2.0 I was able to use the following procedure. I hope that it can be used in WF4, too.
I used configuration buttons marked in the above picture.
Good luck
Martin Hanak
John,
You can use search tool for PRO_MP_DENSITY
> Look for : Solid Model
> Look By: Solid Model
> Include Sub models
> Expression > Symbol = PRO_MP_DENSITY (manually type this)
> value = 1
