Section View not working
EM_12739240
2-Explorer
I am using creo 9 and on one of my drawings I have a section view that isn't showing up. The section shows fine in the model, but on the drawing, hatching appears on the view, but it is not cut.  I have tried flipping it and using a local section instead of a full section and switching from a projection to a standalone view. If anyone has any suggestions, I would greatly appreciate it.Screenshot 2025-05-29 142309.pngScreenshot 2025-05-29 142348.png the
StephenW
(To:EM_12739240)
In the drawing, look at the message log and see if it is saying "x-section aborted".  Occassionally creo has trouble with x-sections in drawings. If I can, I usuaully offset the cutting plane of the x-section by just a little bit, .01, .001, or some relatively small amount and a lot of the time that will let it work.
Just make sure that the little offset doesn't mess up any dimensions created!
Dale_Rosema
(To:EM_12739240)
It looks like the two views are using different planes.
StephenW
(To:EM_12739240)
Dale_Rosema
(To:StephenW)
I forgot about that trick!
Offsetting the cutting plane worked! Thank you so much!
if you can ... upload part+drawing for testing purposes.
Martin Hanák
