I have a detail drawing on two sheet. and some section have the parent view on the 1rst sheet while the section is on the 2nd one.
Unfortunately by doing so I can't get the section arrow to show on the sheet 1.
Is the only solution to create a dummy view outside the frame of the drawing on sheeet 1?
Nicolas
Move the section view in the first sheet, create the section arrow, then move again the section view in the second sheet. See you.
