Sections tab not funtioning in Blend tool...
sbender
Currently one of my co-workers computer does not pop up the sections collector when you click on the sections tab in the blend tool.  It is localized to one user, and I have attempted to re-install the software.  Any ideas on what is wrong?
click File > Options > Windows Settings > Restore Defaults button
-OR-
remove %APPDATA%\PTC directory
Martin Hanák
-OR-
Martin Hanák
sbender
(To:MartinHanak)
This was pretty much correct!
File -> Options -> Windows Setting -> Reset Panes’ Position
The above solved the problem, thanks for the help.
Mahesh_Sharma
22-Sapphire I
(To:sbender)
@sbender
As Martin mentioned use "Reset Panel position" in File > Options > Windows Settings.
Any movement of panel stores in UI file, hence clearing cache also fixes this.
